May 06, 2024 - 06:27 PM
The 10-064X could work. It has a solid metal core so it does not readily flex...you would need to make relief cuts on the underside to allow it to bend - I believe your truck has a slight bend or "dog leg" on the end which would require a bit ef extra fabrication. If you like the look and idea of the 10-064X you might consider ordering samples of all of the materials we have discussed (10-049X & 10-053X also) as well as any others you think may work. Samples are free but we charge a flat $5.95 for postage.
