May 05, 2022 - 10:57 AM
So this material is what GM was using on MANY (not all) 60's vehicles. While the material is spot on, it is sold as a 38" strip which requires you to cut the material to fit. I am not 100% sure if this was used on the 68 Skylark - the best way to determine is to compare to your original. If this material is not a match, we should have a match as we offer a ton of different profiles. You can see all of the different options using the link below. We have samples available as well if need be.
https://www.rubbertherightway.com/win...
